I'm creating a test rig to demonstrate rendering using only an environment map and glow materials. There are no lights in the above scene. I'm getting quite a lot of noise on walls. I'm using interior best as a starting point. Microstation version is SS4. Any suggestions gratefully received.
Thanks Jerry, that seems to help. I love that trick 21 second render. Perfect for quick studies.
