Corners of Luxology render cut off
I'm doing a basic rendering of the site of a school. The google earth image in the background is draped on a flat surface. Not sure why the corners of the rendering are being cut off. The google earth image covers the entire view and there are no clips turned on. I tried different environments, lights, altering the surface, etc. Same results. I've never had this problem or seen this happen with any other renders I've done. Any thoughts? Any help is greatly appreciated.
SS4
08.11.09.872
  • That is weird for sure, do have any perspective on or is the view orthogonal? If you have a camera it must be a telephoto lens, I don't see much in the way of perspective. If this is the case then you could see some clipping if the focal distance is not around the same distance as from the camera to the plane with the draped image.
    Easier to figure out with a test case.
    Cheers,
    Jerry
