CE Update 4: Keyboard Shortcuts don´t save?
is it true, if you change the settings in the keyboard shortcuts, that it doens´t save the changed settings in Connect Edition?
I want to change the "exit" key-in to "Q+W" (or "Ctrl+Q"), but MicroStation save the input only for first time. After i close and open MS CE, the Keyboard Shortcut is not there anymore.
Can anybody test it? I think it doesn´t work.
Marc
