I have a 3D model (attached) with surfaces (in yellow) and I need to "fill" the surfaces as a solid.
The geometry is complicated and this is all I have to work with.
I am really struggling to find a way. Is there a way to do this?
0624.test 3.dgn
I recreated the side surfaces to the "Slide" as I do not believe the existing ones matched. Having recreated I then selected all the surfaces and used the ' Stitch Surfaces ' tool to join them and convert to a solid.
Modified_0624.test 3.dgn
