is it true, if you create a "saved view", that the saved view don´t display the references which you have defined for that saved view? References = on or off.
I mean the reference button in the saved view dialog. Is it a bug?
Marc
Answer Verified By: Marc Winkler
Hi Jerry,
oh, i´ve tested the issue and i have seen, it was my mistake. If you change the levels in the "level display" include the reference levels with global display, there is no change in the saved view. But if you change the levels with on or off in the levels display with view display it function.
Sorry, it was my mistake.
