Is it true, that CE Update 4 can´t attach external materials to the geometry (solid or smart solid/surface etc.)? I have test it and my external materials will not attached. With internal materials is it possible.
Marc
Hey Harshad,
i was testing it again, and in CE Update 4 is it defintly a bug. If you select all geometry and attach the material, the geometry is attached. That´s right.
But it´s all geometry not the face. My goal is to attach the face of the cube. Not the hole cube.
Here some files for you. The dgn with a cube, a Materialtable and a jpg.
for-harshad.dgn
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/19754/01_2D00_Marc.mat
