Hi all,
I have the next problem in MS CE Update 4 / 5, LXP's with pattern maps are visible but the pattern maps are not rendered. They are also visible in the Pattern maps for....dialog but they are not rendered, not even in the render Preview
What could be the problem?
Hi Harshad, thanks for your reply
Yes the variable MS_PATTERN is pointing to the map. See pictures below, any other suggestions?
Hello Mark, thanks for details, I am not able to reproduce issue for Material preview, but i can clearly see issue in render output where mapping is not get seen properly on element . Have filed defect for same Defect 700255:[Regression][From SS4]imported LXP materials wont get seen on element in rendered output
Thanks & Rg Harshad
Answer Verified By: Mark Stals
