Does anyone have a nice material description for Dark and/or Light Architectural Anodized aluminum to assign to storefront window system members? My version of material palette files don't have any such thing and I'm not a real wizard at creating new ones.
Did I possibly see anywherre on BE Communities a repository for User created materials?
I don't believe my licensing criteria allows me to import materials from external palette files (.pal) so the description would need to be screen shots of the material editor or a literal descriptions.
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/19754/Anodized.pal You should be able to open this with our material editor.
Answer Verified By: Allan Becker
Hi Jerry,
This question is off subject but it is the only way I can think of to navigate the "Communities" website since I am sure you know the correct answers.
I have been trying to view the current subject matter regarding "Entourage" within the "Visualization" domain. The results I get from the "Search" box at the top of the page yield links that are for the most part obsolete. I have browsed various related pages and often see notices that say I am required to "join" the group but offer no provision to do so. I am not sure if I am currently a member of the "Visualization" group but think I must be if I am allowed to post here.
Is the discussion group and any related files relating to "Entourage" currently nonexistent or has it moved to a different area?
Is there any way I can confirm or review which BE Communities groups I am registered with?
I probably don't log on as often as most regular members so I need to find out what groups I have joined in the past.
Unknown said:Is there any way I can confirm or review which BE Communities groups I am registered with?
If you go to your profile you have there your "Communities". Inside you can see with which ones you are subscribed.
Entourage is marked as "Archived", so for now, no good sign. Maybe Bentley is thinking this some other way.
José
