LumenRT CONNECT Update 2 not recognizing MicroStation CONNECT update 5 on install - Urgent!
I am having an issue during the install of LumenRT.  The install will not recognize that MicroStation is installed.  I have tried to uninstall and reinstall.  I have installed MicroStation first every time and run as administrator.  It seems like MicroStation is not registered correctly.
I have MicroStation CONNECT Update 5 installed.  Please help!
Azure VM, Microsoft Datacenter 2016, 12 cores, 112 GB, Nvidia M60 (2 cards), 680 GB SSD
Parents Reply
  • Hello Sean,
    Are you using 2d dgn file ?
    Visualization tab is not available in 2D file, Open any 3D file . Visualization tab will be visible , you will find Visualization workflow under workflow drop down.
    While installing "LumenRT connect edition" we try to add exporter for older versions of Microstation. Thats why older release of "Bentley software" get listed in selection list  however Microstation connect edition have inbuilt LumenRT exporter.
    Thanks & Rg
    Harshad
    Answer Verified By: Sean Keene
