File Location when Exporting From AECOsim to LumenRT
When exporting a model from AECOsim to LumenRT - is there a way to control where the LumenRT file will be saved? It always defaults to my local drive, but I want to move it to a shared drive where my AECOsim projects are located, so that others can access them. I can only do a save as or a copy which will break the link to the AECOsim model. I still want the connection between the AECOsim model and the LumenRT model to exist in case there are changes to the model.
 Any help would be appreciated!
Cheers.
Bentley LumenRT Connect Edition – Update 1 Build: 16.01.36.70
Bentley AECOsimBuildingDesigner (10.04.00.26) Windows ×64 and
AECOsim Building Designer V8i SS6 (08.11.09.863)
