Hi all,
Does anyone know where I can find any information regarding using the BIM Information functionality of LumenRT?
I have looked at the Bentley LEARN videos and online and can't find anything at all.
Mark
Hi Mark,
this feature will work in the next release of LumenRT (Connect Edition up 3).
You just click on BIM Info:
then you will be able to just move the mouse over some parts of the objects, when the mouse hovers an area with BIM, it is highlighted with a blue outline: you then have to press the left mouse button to see the bim info:
regards
Mara
Will users be able to display the BIM info be in a published livecube?
Thanks, just one more thing, how's is the BIM Information actually added to the source? Are they item sets or just info from AECOSim? The reason I ask is that we use LumenRT for Civil (OpemRoads) data and would like to add BIM Information to LumenRT.
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Unknown said:Will users be able to display the BIM info be in a published livecube?
Hi Ron,
yes, you just have to make sure the option "show bim info" is checked in the "publish options" panel.
the BIM info are exported into LumenRT from other applications like AECOSim or SketchUp.
