Hi All
I've succeeded in exporting a model from OpenRoads Designer together with an .ani.txt file from vissim. the model shows up correctly with the attached animation. Only pedestrians are not animated. Is this yet to be included in a future release or am I missing something. Currently I'm running LumenRT connect edition
Thanks in advance
Damian, what about adjusting the .ani.txt file so that the peds have a "0" position? I am experimenting with the same issue. I am not sure if adjusting the .ani.txt file would force Lumen to read the peds Lumen library if the peds position was the same as car position?
Any assistance you can provide will be helpful.
