Issue in Save Image dialog.
For PNG and TGA with RGB or RGB Aplha the result is the same - no transparency.
Only TIF works as expected. With RGB no transparency. With RGB Alpha the result give us transparency.
Is this a known issue?
Some similarity with PSD layers for Luxology dialog.
https://communities.bentley.com/products/microstation/microstation_visualization/f/visualization-forum-1977638070/101394/dr-psd-file-with-layers-issue/301185#301185
https://communities.bentley.com/products/microstation/microstation_visualization/f/visualization-forum-1977638070/69532/save-tiff-or-png-with-alpha-channel-from-luxology/181574#181574
When we have this resolved?
We have a TR on this and I believe it should be fixed in CEU7 which will be the next update.
Cheers,
Jerry
Hi Jerry,
I was exporting some rasters recently and I was using the save multiple images option. It was rendering on image out at a time and saving to PNG with the background set to blank, however when I reverted to multiple images, it either filled the background with white or black. Would be great if there is a solution to this? I've tried setting the environment setting to blank but that doesn't seem to work either.
Nic
