When i update an already created LumenRT model including animation (Trees, people, cars etc) with new models, the animation is displaced relative to the models.
Why is this? And is there any way of moving all animated objects at once to coordinate with the models after updating.
/David
Hi David,
which software did you use to update the model?
regards
Mara
If you change the bounding box envelope of the model when re-exporting, it will shift the model. With LumenRT Update2 and greater, it will use the model offset of the first export used to create the initial LiveCube which eliminates any scene alignment issues when re-exporting.
