Depth of Field
Hi All
I have read everything I can find on this forum and am none the wiser, so I am hoping someone can help me please.  I am trying to apply depth of field to a scene, preferably in the luxology render and not in post-processing with Photoshop.
So far, everything I have tried has not worked. Attached are the settings I am using, I have turned on DOF, set the F-stop and played with the anitaliasing a bit.  I can't tell the difference between an image with it set and one with it turned off.  I have set the focal length of the camera - am I correct is my assumption that the area that will be in focus is the yellow plane in the focal length tool and beyond that it will be out of focus?  I suspect there is a setting I am missing, any help would be greatly appreciated.
-W
