I've produced a 2D drawing of a mechanism, I can then use the 'Modify and Resolve constraints' tool to pull an operating handle and the mechanism will work as it should, I now need to send this to an AutoCAD user to discuss, i'm assuming he won't be able to operate the mechanism as i can, and so wondered if there is a tutorial or advice anywhere on animating the arrangement?
I've only done very basic animations before, and key framing doesn't seem to work with constructions/constraints.
Thanks, and any help is much appreciated.
