Is there a rendering option (view or to file) that creates a shape or linestring defining the extent of shadow?
Hello Ian,
The best way to achieve this is create shadow lines from Shadow Generator.
You can type in Search Ribbon:
Or go to Visualization\Home\Utlities\Solar Lightning\Shadow Generator:
Here you can define your options (view, quality, source, output mode, etc):
Then check your render options and make sure you have Render Visible Edges turn on and check the parameters:
When the render is finished go to bottom right corner "..." \Display\ and turn on Visible Edges
Search help for Shadow Generator to help you guide through the process.
Hope this helps and is what you're looking for.
José
Answer Verified By: Ian Gorrie
Cheers Jose - that worked well but didn't adopt symbology set for Render Visible Edges
but no big deal - good result
