Hallo everybody,since I've upgraded to windows 10 I can't open any Skp (sketchup ) files!Does anyone have a solution for this?
Thanks.
Hi Jorge,
I cannot imagine that Windows 10 has anything to do with it, I open SKP files all the time and I am on Windows 10.
What are you opening them with and have you tried downloading something from 3D Warehouse? Might want to do a disk check.
Cheers,
Jerry
Thank you for that Jerry. I've successfully downloaded :https://3dwarehouse.sketchup.com/model/ub758428b-00a2-400c-92f4-33f5144c2bee/Huerto-ecologico-terraza
but when I try to open it with MicroStation I get the message above.
We are always a little behind these guys they change every year, try downloading older version like 2015 that worked for me.
Thank you again Jerry. I tried all the downloads, even the Collada file. None worked..
What version of MicroStation are you using?
