After 5 years not solved
SS4 and Connect.... Its really hard to make it to match illustration mode ?
5 years.... unbelievable
Stich into single surface help a lot for preview - but it's not this problem
in illustration mode looks ok .. but luxology > no matter parametric, or planar , or cubic....
Can you send me the test case just that piece of geometry and the texture and I will have a look?
Jerry
<Bentley_5F00_Communities_5F00_RGB_5F00_Stacked_5F00_244x88-png_2D00_125x44-png> Update from Bentley Communities <4TJYBL9BWXYU-jpg_2D00_70x70x2-jpg> Jerry Flynn Can you send me the test case just that piece of geometry and the texture and I will have a look? Thanks Jerry View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
I have error while try to upload...
The problem is that ( not only visualisation ) , that Bentley make some new things but older things are still not good.
Like new Connect interface - better to fix all the bugs and than something new
Hi Martin,
I got the test case thanks I believe the problem is with the BSpline curve you used to create the surface. I noticed when I selected the curve that it has an odd number of poles. When I zoomed in on the area show in the red circle below image I could see the problem. I think that if you clean that up and construct a new surface you will have more success.
