Thanks as usuall for your answers. As above how does one get the above plug-in installed into Revit2017? And secondly how do I find the plug-in thr ESRI CityEngine.
Dan Martin
You may have to run a repair on the LumenRT installation for it to show up.
So does that mean that I have to re-install RT(I can't find a "repair" function/button in lumenRT.
Dan Marton
I believe David was telling you from the windows installed programs.
Double click on your LumenRT and you can choose install or repair.
José
Hi Jose
I feel rather stupid asking this but I cant' find "Windows installed Programs" DUH is there not away to "repair" Lumen RT?
Thanks! Dan Martin
Windows 7:
https://support.microsoft.com/en-us/help/2601726
Windows 10:
https://support.microsoft.com/en-us/help/4028054/windows-repair-or-remove-programs-in-windows-10
In both versions the program configuration should give you the possibility to repair. Some programs have that and some do not.
