I have a LumenRT scene that I had setup. I made a handful of updates and kept saving every 20 minutes or so. I ran a low quality video that worked great, but was at the fast setting and I wanted to get it updated with a Fine setting. When I tried closing the file, LumenRT crashed. When i try to reopen the scene, I get the error, "LumenRT could not open the selected scene. Please ensure that you have enough disk space available. If you do your scene may have been corrupted." When i closed the file ,i realized i was indeed low on disk space, which i then cleared out 10 free gigs.
I've tried copying the .bak file, to a different name and changing .lrt file, but get the same error. Is there anything else I can try to restore my scene?
Any help would be great. I have a public meeting tomorrow and don't have the time to set everything up again and troubleshoot, so worst case i can just use the Fast quality version.
Brian
Hi Brian,
The Eon guys in Paris might be able to open it. If you can post it and we give it a try.
Cheers,
Jerry
I've posted it to ftp://ftp.bentley.com/pub/incoming/, should it go somewhere else? I've posted both the .lrt and the .bak files.
Jerry, I've tried redoing my scene. The biggest reason I wanted my old .lrt file was the fact that the traffic worked under the underpass correctly. I'm constantly fighting traffic to stop from jumping up to overpass. Is there a good trick for this or a setting I may be missing? I've tried turning off the overpass levels and placing lots of the traffic points through overpass location, but the second i turn on the levels, traffic goes back to hoping on top. I try to keep up with alot of the questions and discussion on here, but I've never been able to get the traffic to consistently work correctly where there are bridges overhead. Sometimes it works, sometimes it doesn't, and I can't quite explain why it does work when it does.
Are you exporting the scene from MicroStation using MicroStation's traffic animation?
If you want to create a Packager file I can try exporting the scene to LumenRT for you to see what is wrong.
Alex is looking at your files now,
I inspected your .lrt and .bak files. It appears the files are truncated, as if the save operation has been aborted in the middle of the process.Unfortunately in this case it is impossible to restore the file.
Regards,Alex
