I can't seem to get my 3D mouse to work in LumenRT or ConceptStation but heard at the OpenRoads conference that they support 3d mice. Is this true or does the software not support it? Also, are there plans to allow use of 3d mice in ContextCapture at some point?
Thanks in advance.
I have the 3DConnexion SpaceMouse Wireless and it works in the Connect Edition of LumenRT. It did not work in previous versions. I'm a big fan of them if you're able to get them to work. If I touch the little side buttons, an error message pops up for me, so I only use the 3D mouse to navigate and use my regular G700s mouse buttons for any clicking.
That was the issue, my shortcut was still for 2016 but as soon as I switched to Connect it worked fine. I did not have any trouble with the buttons on the side but I usually just use one for the mouse Properties and the other I set to LumenRT>Front View. Thanks for your help!
I am using 3D connexion Space Mousw with LumenRT, works fine. But unfortunetely seems not to work with LiveCube published. Have you tired to use it with models pblished to live cubes? Did I miss sth while publishing?
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
