Hi everyone
I am trying to figure out some rendering in Aecosim for a bridge with volume lights but after try again again I am finaly here asking for your experience to share.
I want to render night view with street light volumetric and some good envirnement but I don't know about render settings kindly share your experience by setting render settings.
I am attaching two images
1 for autocad I have done and
2nd for aecosim and I want to make it similar to that of autocad.
Some starting points by Jerry Flynn here:
Luxology Environmentshttp://communities.bentley.com/products/microstation/microstation_visualization/b/luxology-blog/archive/2009/08/13/all-about-luxology-environments
Splotches, Blotches and Light Noise "Oh My"http://communities.bentley.com/products/microstation/microstation_visualization/m/luxology-files/104108
Tricks of the Trade Volume Lightinghttp://communities.bentley.com/products/microstation/microstation_visualization/b/luxology-blog/archive/2009/05/08/tricks-of-the-trade-volume-lighting
On foghttp://communities.bentley.com/products/microstation/microstation_visualization/b/luxology-blog/archive/2011/08/05/clearly-through-the-fog
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
Hi Sir
Thanks for your info. But unfortunately I am not able to make environment similar above I done in AutoCAD render.
when I tried using different environments from Aecosim Environment managers then I am not able to see light illuminitations. its become hard for lights setups as well.
I need some screen shots if possible for you with light setups and environment setups so I can follow through. else its time consuming.
will use autocad insteed.
Kind Regards.
Muhammad Ismail
You can use the Effects Manager.-Start Effects Manager.-Start Render Image Set.-Adjust color, brightness et cetera for each individual light source in the Effects Manager.-When satisfied, push values back to light setup by pressing Update Designfile Lighting.Also, you are using the Luxology render engine, right? Not the DirectX display.If I'm not mistaking you are using volumetric light for each and every light source. Wich is not visible in the acad example. Try switching of the volumes to save massive on render time.Turn on Flash Light or Ambient to bring in some overall lighting.
