Working in MicroStation CONNECT Edition I am trying to export my model to LumenRT using the plugin provided. Everything seems to export correctly, all of my levels are displayed in the level manager within Lumen and turned on, but there is no visible corridor in the model, just a brown square that I'm guessing is where my model should be. Anyone else have this problem?
Hi Ariel,
are you exporting meshes? I recall a similar issue, but it could be also on your file specific.
Which version of the software (Microstation and LumenRT) are you using?
regards
Mara
