Can I somehow remove the terrain from my LumenRT model? I want a completely empty model. I'm talking about removing the pre-defined terrains, like "Simple ground".
Hi Christian,
you can load the Simple ground terrain: https://communities.bentley.com/products/microstation/microstation_visualization/w/microstation_visualization_wiki/36991/how-to-load-a-different-terrain
regards
Mara
Hi Mara,
Thanks but I want an empty model. No ground plane.
Not currently that I know of sounds reasonably though for future version. I will ask developers to see if we might have workaround.
Cheers,
Jerry
