Hi
Can i Convert the annotations in Microstation in to something that is possible to import in to LumenRT?
Helge
Hi Helgeh,
only things that can be converted to polygons are handled by LumenRT.
regards
Mara
To add to Mara"s answer, turning text into polygons can be done via 2 ways:
Either tools may be applied on whole file in one shot.Example : up, dropped text, below, extruded text
Vincent RAULT [Bentley]
How about lines, can they somehow be converted to polygons?
just apply a linestyle with a width and it will appear in LumenRT
Hi Vincent
Can you explain how you did that, what line type did you use? I tried to draw a some lines and change line weight to give it thickness using Microstation standard line nr 0, but this will not import to LumenRT.
