I'm supporting a client setting up DR (V8i SS3 08.11.09.459 - all on Win10 (Dell) systems)
DR works fine, but there are no processors listed in the Job Monitor. Only the Current Jobs data is in the top dialog section.
The bottom section of the Job Monitor doesn't show any information
The 'workers' directory (sub-directory of 'Projects/Renderfarm/jobs/<Job-ID>/' shows all processors (as .xml files) which do contain the current status e.g. what the 'worker' is working on.
How to get the Job Monitor displaying this information ?
Rgrds,
Pierre
Hi Pierre,
Did you click on the job in the top section? That should cause the information to display. Perhaps a screen shot would help....
Make sure that the that your start the Distributed Rendering Controller on all the machines that are going to participate in the render job. If you failed to do this the job monitor will not show any machines running.
Cheers,
Jerry
Okay I have heard of this before but never had the issue myself so I will have to consult with a developer and get back with you.
