I am having an issue with LumenRT animated traffic "freezing" and remaining static for the duration of the animation, both in real time and when exporting a movie. The real time is an annoyance, but the freezing/locking up during recording is making the output unusable. It appears to be triggered by transitions between clips. The frozen vehicle will remain in place and animated vehicles will pass through it.
The traffic is being animated within LumenRT, this is not the result of a VISSIM or Microstation traffic import.
Any ideas?
It appears the animation resets between clips as well. Is it possible to force Lumen to maintain the same position in the animation loop between clips?
Thank you,
David
hello Dave,
the freezing/locking of animated car is because of resolution problem this happens when you change between real-time and exporting the video But you can do one thing to get it right you just have to select the path of the animated Vehicle and click on play animation again so the car will start from normal you will find no car is overlapping and quickly export the video so that the output will come good. Although this issue has been fixed in latest edition of LumenRT update 4.
Ankur Ashesh
