Hallo everyone:-)
Unfortunately and inadvertedly I managed to rotate my A2 sheet 1.33 degrees.
This has been solved by rotating it back. Except for the shadow (?) background of the A3 which I wasn't able to rotate back.
Any ideas about how to solve this?
Thanks.
Jorge
Please post your query on the appropriate product forum, as the answer may vary depending on the product being used. For example
MicroStation https://communities.bentley.com/products/microstation/f/microstation-forum#pi25830=1
AECOsim https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum#pi25858=1
Carl Myhill
Technical Support Engineer
Bentley Systems
