Placing my Plan call out, I get what you can you can see in the image. What is going on? Any ideas?
Thanks.
Jorge
Please provide some additional information on the problem.
It may be more appropriate to post your query on the appropriate product forum for example
MicroStation https://communities.bentley.com/products/microstation/f/microstation-forum#pi25830=1
AECOsim https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum#pi25858=1
Which product and version is being used?
The image shows what appears to be an elevation and some elements are not being clipped by the plan call out. Can these elements be selected ? may be the element information can provide some hints as to where these long lines are coming from.
Are these elements displayed prior to placing the plan callout or do they appear after ?
Are the elements in this file or a reference and if in a reference are other elements in the reference clipped ?
If possible post sample file illustrating the issue for others to review/comment
Carl Myhill
Technical Support Engineer
Bentley Systems
