Hi
I have been looking for this for a while now but are not able to locate it. Where can i find the LumenRT content MicroStation cell library? I am using MS Connect U7 with LumenRT Designer.
Helge
The path should be similar to the following:
C:\ProgramData\Bentley\Bentley LumenRT CONNECT Edition - Update 2\LumenRT Content\MicroStation\
You can also search for the cell library itself named "LumenRT_Content.cel"
Answer Verified By: helgeh
Thank you David, i found it!
