Trees and people are equally shifted from original place (see pic). It happens on the second opening of LumenRT. Does anyone have any idea? Thank You
PowerCivil V8i SS4 08.11.09.789
LumenRT 2015 08.11.09.655
Am I the only who has such kind of surprise ?
No one ever had it ? Ever ?
LumenRT Update2 - no changes. Problem is still alive.
Any suggestions ?
Hi Maksim,
Bentley LumenRT CONNECT Edition Update 4 (version16.04.04.94) is available from thew Bentley Software Downloads.
I would recommend giving this version a try.
Hey Maksim,
You may have place LumenRT objects after accidentally moving the design file's x,y while moving it closer to the surface. I've done this once before. Once you re-exported, objects still maintained the position while design file moved back to correct location. Not sure if this is what happened. Make sure you are careful moving design (z direction) in LumenRT and once you move it, make sure to check box back to lock transform.
Another option to try is delete .bak and re-export. Or uncheck lock transform and move design into position.
Hey Bob,
I am sorry I did not quite understand your * accidentally moving the design file's x,y while moving it closer to the surface * but if you mean dgn file by * design file * then I would ruled it out because shift is not the same on every next opening. I am pretty sure that MS 3d model keeps the same location just because there is no need to change location. More over it has no changes as a 3d model.
Regarding Z direction in LumenRT: there is only rotate action for people and cars, rotate and scale action for house and some trees, no action for the forest. All those guys just jump on the surface they found so there is no need to move anything in z direction.
Regarding .bak file: It is kind of problem right now. I uninstalled and deleted everything I could find to uninstall and delete today. It is testdrive of Update 4 right now. All I need to do is just to wait a little bit when the problem comes back.
Thank you Bob for your suggestions, recommendations and guesses.
I will come back with this problem as soon as it gets back. If it does.
