I have an fbx file with an aerial image on it in MicroStation but when I exported it to LumenRT the material is rotated and I cant get it right again in LumenRT.
Any ideas?
//Christiaan
Hi Christiaan,
the question is what is incorrectly rotated mesh or draped image in LumenRT , it looks on two separated processes made by lumenRT
I saw something likewise with the same terrain with two 3mx and 3sm rotated each other
probably David Burdick is right man for it
karol
Hi Karol, The image in LumenRT is rotated the one in MS is just fine
I am having a similar issue. I am running Microstation v8i and in Microstation view my draped image looks correct, but when I export into LumenRT, the Aerial-drapped image (which is draped on a mesh) is rotated a random way. I did not have this problem a few weeks back.
Has anyone found an solution for this?
Although I haven't had this particular issue, I've had issues with draped imagery not exporting when using the Large Model Export option. A work around that I have done is to export the draped image as an OBJ. Once in LumenRT, load imagery to dcdrape surface. No scaling or moving is necessary. Note: resolution is still low due to dcdrape option.
HI Christiaan,
Which version of Microstation are you using ? If you send me a testcase I can take a look.
Paul
