I have a DGN with two Models. The one contains buildings and the other contains a terrain mesh.
My display style is Illustration: Shadows in the Default model (with the buildings). I’ve referenced the terrain mesh Model with Presentation = Smooth.
Why does the terrain mesh still show triangle lines? In theory it should now be Smooth, while the buildings are Illustration: Shadows
Any ideas?
It's worth a bump on this - I'd really like to get it working...
The interesting thing is that it does work for half a second, but the lines always return thereafter. Could it be a display card issue?
(Nvidia Quadro M4000)
Hi Max,
We have some new mesh tools in CONNECT Edition you can modify the mesh display to get what you want.
Cheers,
Jerry
Answer Verified By: Max Voigt
Thanks Jerry - that works well.
There's a very real risk now that I might actually transition to CONNECT!
Max
Hi Max
on v8i you have to type:
"facet modify hideedges"
ciao
