Hi, I have created the frame of a structure using shapes generated by Prosteel (I-beams, tubes, plates, etc.) and would like to animate parts of it. I have tried using the animate tools but they do not recognize the Prosteel items. I can create solids using the Microstation tools and then get them to animate, but when I try to select a shape I created with Prosteel it won't recognize the part.
Is there a way to animate Prosteel generated shapes?
Thank you,-Dave
Can you send me a simple file so I can take a look.
Paul
