Hi all,
How to add a tree to MS from Lumenrt, when I modeled the tree in Plant Factory?
best regards
1) Create a Plant in Plant factory.2) Export Plant to LumenRT (.lob) from File > Export >Export to LumenRT3) Copy LOB file to C:\ProgramData\Bentley\Bentley LumenRT CONNECT Edition - Update 4\LumenRT Content\LumenRT\Plants4) Export same plant to Mesh (FBX or Obj ) from File > Export > Export to Mesh5) create .cel file with Tree Mesh in Microstation6) with Model name start with LRT_Plants_ name7) Create a cell for tree in .cel file with name starting LRT_Plants.
Note : Make sure Tree name in .Cel file and in LOB is same for
example: TreeMango
LOB name : TreeMango.lob
>cel name: LRT_Plants_Treemango
Test: Create new dgn file in microstationplace tree cel from above create .cel fileexport dgn to LumenRT from Visualization > Home >LumenRTObserve in LumenRT exact same tree will get picked (LOB)
hi harshad,
thanks sosososo much. That helped me a lot.
Sincerely,
Dongcai
hi harshad, when I copy a new plant lob file in a new created folder and export my dgn file to LRT,there is some error:couldn't loadproxy object !
how can I creat new plants like other plants already existing in the PLANTS folder?
Hello JXD,
will you please let me know LumenRT and Plantfactory version number?
Also if you create new LRT and browse for plant , do you see your custom plant in plant browser under Folder name ? you able to place custom plant in lrt file directly ?
Thanks & Rg
Harshad
helle harshad,
my LRTversion is Bentley LumenRT CONNECT Edition - Update 11 and Plantfactory version is PlantFactory Producer 2016 R4.
as shown in pictures above,my custom plant can be placed in lrt file.
