Hi Everyone,
I have been using LumenRT for a few years now. When I reload a scene after having saved it from a prior session it always opens with the default date of November 8th, regardless of what I had it set at when I saved it. Is there a way for my date and time to save and reload correctly or will I always be doomed to readjusting it everytime I reload it? Also is there a way to change the default date? I would rather use something in June or Jully with a higher sun angle and better tree color.
as far as I understood the seetings, these are stored in the movie keyframes resp. in the photostrip; so you have to add items to those by clicking on the camera after having found your ideal settings for everything (season, time, lightning, etc.); note that the behaviour of the camera icon can be modified in the camera settings, so as to just add key frames to the movie resp. to the photostrip ...
But you are correct: Some things which might work are not evident; I myself (up to Upgrade 3) got upset with the adding lights feature, as - after opening a prior session - these seem to disappear or simply are not indivually addressable any more ...
