Rendering large models in Aecosim Connect - Problems
So, attempting to render a large model in ABD Connect, i get this....
The 'render' never completes, or if by chance it does, it is just black. There is no progress bar, does not display light passes etc....  just using a whole lot of RAM
Nothing to do with brightness settings or lighting. I can render the same model in MS Connect without issue, though I have to manually assign materials as the parts are not recognised in MS.
I shall post the same question in the Aecosim forum, but as MS can produce a render i tend to think the issue is with part/family mapping and ABD
