Hi all,
I'm struggling with the traffic animation from MicroStation CE update 8 to LumenRT.
I want to create an animation with my custom cars(from Cell) and a Sphere to show me the actual distance true the animation.
It looks good in MicroStation see animation.
Export to LumenRT, there is no red Spehere as it was in MicroStation:
Thank sin Advance.
//Christiaan
Hello Christiaan,
Please check attached video .
there is trick to do that .
You need to create LOB files for elements which you want to use in traffic animation and need to copy them in LumenRT library , in microstation you can create Cells name with starting prefix of LRT_.
test.dgnSphere.zip
Thanks & Rg
Harshad
Hi Harshad,
Yes I have had that solution from Ron Jones.....
https://communities.bentley.com/products/microstation/microstation_visualization/f/visualization-forum-1977638070/142514/invisible-material-in-lumenrt/436204#436204\
but we must have the option to export all kind of camera animations from MicroStation in to LumenRT because it's mutch easier to this don in MS
How do I get this animation in to a liveCube I cant get this to work and even it mesh up when you put it into a VR headset, you can't play the animation In LumenRT.
See video
https://vimeo.com/260250264
