Hi you all
Based on your experience which is the better way to export a MS model in order to use it in 3DStudio Max and still control layers and independent elements?
Lot's of thanks
Borga,
We've had success with the *.obj and *.fbx. Depending on what your'e doing you may want to look at LumenRT - makes adding people, trees, traffic very easy.
Tom F.
Exporting the model to fbx should work. If objects are forgotten, convert them to mesh first.
Hi Tom
Lot's of thanks for the answer. We want to create static renderings with vray or corona.
We know LumenRT is great for another kind of works.
Lots of thanks for the answer Louis
We will try
Have you tried Vray and Sketchup ?
You can easily export to Sketchup and render with Vray
