When using a 3SM in LumenRT, geometry in any areas that are masked (hidden) still affect vehicles and characters that are driving or walking in these areas. If the masked (hidden) area is higher than the other geometry, any objects placed there will float above the other geometry because the masked (hidden) area of the 3SM is still detected. You can place vehicles and characters correctly if you uncheck the 3SM layer, but when you later recheck the 3SM layer the vehicles and characters movements will be adjusted to the masked (hidden) areas of the 3SM, even if you lock the transform of the vehicles and characters.
This is unacceptable behavior and needs to be fixed!
Anyone from Bentley have a comment?
Hello Ron,
Thanks for reporting issue
i have created defect#888335 to trackdown this issue
Answer Verified By: Ron Jones
I realy hope this one get fixed in the next update!
I just checked this in LumenRT Update 10 and it works. The masked area of the 3SM no longer affects LumenRT content positions.
Thanks to you and Laurent for getting this fixed!
I can see the clip in connect but not in lumenrt. How is this done?
