Hello
do you know why my sun shadows are not parallel ?
https://we.tl/KTdQOaGjmJ (dgn file )
Martin
Hi Martin,
I really don't see anything wrong with the shadows and when I rendered it the shadows looked correct. look at the shadows from the three flag poles.
Cheers,
Jerry
Jerry, based on line A - rest should be like green lines but are like red...
Okay I am going to say this is some optical illusion from the camera perspective if you render orthogonal non camera view then you will get parallel shadows.
Answer Verified By: martinezx
I have 2 points perspective... i always thought that is the same / similar. Thank you for clear
Two point perspective can get really weird at extreme viewing angles usually you want to use that when on ground looking up at a building and not from overhead looking down... mystery solved.
