Hallo Pierre,
have you tested distributed rendering with Connect Edition? We have a lot of problems with distributed Rendering in Connect Edition, especially if we use distributed Rendering in connection with the skript-File "Rendering Multiple Images". Partly rendering never stops or uses ten-time more rendertime, as if it would be started without the skript.
Thanks Gerd
Hallo Gerd,
No, we're still using MS SS3, so I can't say anything wrt to the issue you have with the Connect Edition.
Regards Pierre
I am using ss4 this days, previously ss3.personally I found that all machines should be as close as possible for being identical. Regional settings, file names etc.
For example i found the file created in German version of mstn cannot be rendered in Russian mstn, simply because difference in OS internal date format and file names.
We have agreed internally, that we use international (UK) setting for all mstn across our offices for files and regional settings. This is a small compromise for my colleagues, but the simple solution for get things done.
Nikolay Vyglazov
