I red Camera paths can be exported to LumenRT. Unfortunately if I export a model with camera path, this isn't visible in LumenRT.
Am I doing something wrong?
Regards Louis
Hi Louis,
Sorry the cameras on paths are not yet supported but are on our to do list. What you can do is create animation using saved views these are exported but you would most likely will need to adjust the time between frames in LumenRT timeline.
Jerry
Thanks Jerry,
My client asked a drive thru over a sinuous bicycle bridge (on eye height). You're tip is faster than my current workflow. Thanks!
Rg Louis
the easiest way is to create a animation path for cyclist /in LumenRT is Omarie :-)/ and then to add camera on head /or eyes / of cyclist and make video max half hour job ,done , it works great without any problem , few day ago I finished really great and complicated 3d model of crossroad and then precised it in LumenRT included 4 videos more than 2 min each from cars and livecube and so on , now i sent cyclist, look of very fast video in gallery /files
Andrej
Thanks Andrej!
