Now I can't use MicrStation Connect Edition, I've got a serious problem.
I have to make an animation in LumenRT, but in MicroStation SelectSeries 4 (instead of Connect) I don't see the LumenRT buttons (I've re-installed it and choosed MicroStation SelectSeries 4 as software for plugin).
What am I doing wrong?
Regards Louis
Did you install SS4 after you already had LumenRT installed if so you may have to run the installer of LumenRT for the plugin to be installed.
Thanks David,
It worked after I referred the MS_GUIDGNLIBLIST and MS_DGNLIBLIST.
Now I only get an other problem. My saved views aren't exported.
Is there a solution to this?
