Removing a material color change
Hi all,
Working with LumenRT 5: I have  attached the LumenRT material LRTGRASS1 to a surface. All surfaces on the same level have automaticaaly get the same material. I tried to change the color of the grass,
Now I don't want to have the color change anymore, but the Remove option is not available. How to remove the color change?  (In the meanwhile I have saved the file < I can not undo anymore)
Best regards
Parents Reply Children
