Is LumenRT compatible with CityEngine 2017.1?
If so, could someone explain to me how I can install it?
Please use the following link to download the reference manual for LumenRT:
https://bentley.sharefile.com/d-sca13795a9ef4633a
Chansoo Byeon said:If so, could someone explain to me how I can install it?
During the LumenRT installation process make sure that when at the plugin installation screen that CityEngine is selected for the appropriate components to be installed.
Hi, David
Thanks for the reply. I just re-downloaded the installer but I dont see the CE 2017.1 option in the installer.
I downloaded the installer from the Bentley's main page: https://www.bentley.com/en/perspectives-and-viewpoints/topics/campaign/lumenrt
Is this not the latest installer?
The version available through that link is Update 3 of LumenRT. Support for 2017.1 was added in Update 4 and the latest version of LumenRT is update 5. If you have access to our Download Site you can download the latest version.
Answer Verified By: Chansoo Byeon
Hi, David!
Thanks for the link for the latest installer. They should really put it in the main download page. This seems hidden.
I could not find a download button however. Where should I click to get the download going?
There should be a button under the Download column, perhaps the image is just not loading. You may want to try a different browser.
