I am trying out materials in V8i SS3 and want to use a grey block but it's too dark. How can I make this material lighter?
Hi J-Worker,
Check if you working with default like this (off) or turned on:
Also check the overall brightness here and if different place like this:
Hope this helps and regards
José
To the right of the preview the mode is set to shaded, change that to be Luxology and a cube would be better than rectangle for the display. You can also move the slider to the right under the preview.
Jerry
In addition to the other suggestions, What is the Display Style you are using?
Shaded
Do you have any lights turned on ?
