PDF
When I try to open a DWG file in Microstation, it does not open up with texture? Could someone please guide me on this? I have added a PDF document of how I am able to view the DGN file in Bentley View and how the DWG file appears on Microstation.
Your images are showing the DGN in Bentley View and the DWG in MicroStation Connect Edition, What is not clear from the images alone is how the elements were created and the material applied and also the product versions used.
The issue may be related to an existing Defect 696558 see this thread https://communities.bentley.com/products/interoperability/f/fileformats-forum/143085/why-microstation-connect-edition-6-doesn-t-export-fbx-with-textures/434319#434319
Also see https://communities.bentley.com/products/microstation/microstation_visualization/f/visualization-forum-1977638070/78705/howto-export-a-dgn-with-a-dcdrape-material-to-dwg
Please post the file for others to review and comment, or log a Service Request with Bentley support
Carl Myhill
Technical Support Engineer
Bentley Systems
