Hi there,
I'm facing problems producing a building interior animation. Some of the features are constantly appearing and disappearing, such as windows and doors.
Could you please give me some tips to solve this??
Thank you all!
Kind regards.
Jorge Marques
Hi Jorge,
Jorge Marques said:I'm facing problems producing a building interior animation. Some of the features are constantly appearing and disappearing, such as windows and doors.
Are you talking in the view displays or in render output?
What is your Windows version?
Size of the file and the amount of RAM?
José
Hi José.
Thanks for helping.
I´m working with windows 7 - 64 Bits and have 16Gb RAM.
The size of the file is about 3,92Mb.
Ok, just one question missing:
Jose Pinho said:Are you talking in the view displays or in render output?
At fist I tried Luxology render. But it didn't work. My computer just couldn't handle it.
But now I'm using render mode from view (Smooth Modeling). Is this what you're asking?
Yes, thank you.
I'm curious as you said your computer couldn't handle Luxology render. Very strange as this is a powerfull render engine and you have a low file size.
Your elements are created from scratch inside Microstation or they came from other program? Are you using shared cells or normal cells?
Or other possible issue is your material definitions. Are you working with displacement maps and or fur? As this kind of definitions make your render time go very high.
Perhaps you should create a simpler file and post here in which we all can see the flickering happening. To post your DGN file here you'll have to create a ZIP file.
And you should move this post to Visualization forum.
